Hi @adifrank, could you please use the Left ≡ menu → Support → Report a bug?
Are all sounds marked with the snore tag?
Hi, Sorry for late reply. No none are tagged, all are recorded as noise. I have sent mail via report a bug.
Does talking and snoring for example count as “not sleeping”? One night I went to bed around 00:00 and woke up 8:00 but saw it only counted 5h as from 0-3 I talked or the podcast got recorded even to an other parameter like breatrate or REM sleep indicator was low
Hi @Zepuuu, this depends on your configuration for awake detection sensitivity. If you listen to podcast while sleeping, consider lowering or disabling the Sound recognition awake detection in Settings > Sleep tracking > Awake detection
Detected awake periods are subtracted from the tracking duration, so the sleep duration might be shorter than the tracking duration.
