Sleep fails to connect with Ikea Tradfri Gateway
After I changed my phone from Galaxy S20 FE 5G snapdragon to Galaxy S23, Sleep as Android data was transferem between phones, including smartlight integration.
Unfortunately, when I’m trying to test integration it fails without any error.
I tried to disconnect bridge and connect it again. Sleep fails in automatic searching for the bridge with “Failure Timeout” Error.
(Ikea app don’t - connected immediately, and I’m sure I’m on the same network).
I’ve entered bridge IP address, and was asked to enter code or scan QR code. Every attempt fails with error “Hue cannot find your bridge. Please check that it is connected…”
Steps to reproduce:
As above
Hello @TheKosmos96, big thanks for reporting this issue. We should have a fix, now confirmed.
To get the fix please first join our BETA Testers group at:
or simply by visiting our Play Store listing and tapping “Join BETA”
