It doesn’t take long for the folder of sleep audio files to build up. Is there any way to delete files from within the app? Can I control any history records from within the app? Thanks
Hello, sure… by default we delete any files older than 1 week… and you can long press on any audio file and choose delete older than or all unstarred…
Also you can have higher recording thresholds to produce less aduio files in the first place…
