For some reason, alarms that I’ve chosen to skip, still appear.
Steps to reproduce:
- Open an alarm set to repeat.
- Select “Skip Next”.
- Wait for it to go off anyway.
I’m running version 20190719 however, this issue was present in the previous build too.
Thank you for your assistance with this issue. On days when I have to get up much earlier than normal, this is becoming quite the problem.
