From Joss Terrell on 2014/09/29 09:14:48 +0000
I like waking up with only a vibration, rather than a noisy alarm, however it appears the only way I can set this is on a per alarm basis.
Can a silent alarm be added to the application settings as well?
This way, newly created alarms and naps do not need to be adjusted to silent before use.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6498019-silent-alarm-as-application-setting
From Concerned Sleeper on 2017/01/02 16:39:24 +0000
I want to second this idea, I use wearable vibration for waking up and setting every alarm to silent manually is bothersome. A silent default option is most welcome.
