From Gokhan Pinar on 2016/01/06 07:31:06 +0000
Wake me up 2 hours before when I have an early (between 7 to 9 am) meeting tomorrow.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/11323941-set-edit-alarm-commands-for-tasker
From Petr Nálevka on 2017/06/06 08:40:19 +0000
You can enable/disable alarms based on their labels through tasker, please check here:
From J.F. Nash on 2017/06/06 00:39:35 +0000
I would need to activate or deactivate my alarm named "Wake up early" when Tasker detects a profile called "Workday" and the alarm called "Sleep late" when Tasker detects a profile called "Holiday". It is NOT based only in calendar. It is based in other elements. Is it really so complicated to set an activate/deactivate switch with a dropdown to select an alarm by name?
From Gokhan Pinar on 2016/01/06 11:10:52 +0000
Hmmm. I'll take a look at. Thanks.
