Separate nap Alarm settings
From T on 2017/02/19 21:55:54 +0000
You can set the nap Alarm to “vibrate“ and leave the normal alarm with a separate ringtone.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/18388381-separate-nap-alarm-settings
