Samsung One UI 8.5 Brief notification pop-ups are not filtered by Twilight
Hi, I’m having an issue with Twilight on a Samsung Galaxy S25 FE (SM-S731B/DS), Android 16 / One UI 8.5.
Twilight’s Accessibility Service and “Appear on top” permission are both enabled.
Twilight correctly filters the status bar, Quick Settings, volume panel, and Samsung’s Detailed notification pop-ups.
However, Samsung’s Brief notification pop-ups appear above the Twilight filter and remain bright/untinted.
If I switch the notification pop-up style from Brief to Detailed, the exact same notification is correctly filtered by Twilight.
I use Twilight with the Sun schedule and gradual transition, so I would like to keep Samsung’s Brief notification style while having it receive the same Twilight tint as the rest of the screen.
Is this something Twilight can fix or work around on One UI 8.5?
