Results: Sonar or Accelerometer
How does one determine if testing was done under accelerometer or sonar?
Need to denote clearly which was active during sleep cycle
You determine that by going into settings, sleep tracking, then sensors and choose accelerometer or sonar. Using sonar the phone sits on your bedside table. Using accelerometer means having the phone on the bed near you. Hope that helps. It would be nice to see some sort of indication on the page where you start tracking though.
Sonar ses kaydı almıyor neden acaba horlama kaydı almıyor garip sesler Ƨıkıyor
Hello, in the morning on the sleep graph you see a sonar tag if sonar was used to record your activity…
Regarding recording… if you listen back to any recordings to you see some sonar artifact?
