Remove dro down menu for Trend and Tags
From Chris on 2018/02/25 09:36:53 +0000
Can the Trend and Tags go back to a scrolling screen instead of a drop down menu? It used to be so much easier to navigate quickly.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/33443053-remove-dro-down-menu-for-trend-and-tags
From Chris on 2018/02/27 16:08:09 +0000
I found it easier to scroll through the graphs (up and down) without having to select each graph one at a time. The Chronotype and Advice tabs can still be scrolled through. I find that easier to access.
