20230419
- Google Assistant integration see https://shorturl.at/qkloC for details
- Total sleep score can be prioritized (ordered) like the other score measures
- Last average is shown on graphs in legend
20230420
- Fix for noise being recorded when tracking is otherwise suspended because the device is low on battery
20230426
- Fix for crashing bug in Health Connect sync
- Average shown even for week / 14 days charts
- Cute droid looking into fridge animation when no sleep data has been collected
20230505
- HealthConnect SPO2 and HR sync
- Keep sleep tracking and alarm notification persistent even on Android 13
- Selection Wear OS 3+ watches does not require a particular companion app
- Fix for purchasing the yearly plan
20230512
- Specific Lullaby album art in notification
- Support for 3 new lullabies from Lullaby Add-on:
- Humming
- Candy ASMR
- Reading ASMR
20230516
- New online radio lullaby icon
20230517
- Fix to update smart period if changed after sleep tracking has started
- Allow up to “repeat every 16 days” for non-weekly schedules to support 4*4 DuPont system
20230523
- Health Connect fixed, permissions, indicator, edit button leads to Health connect configuration
20230526
- Potential fix fo Band notification posted error
20230529
- Better subscription terms explanation
20230606
- Targeting Android 13 APIs
- Latest Billing APIs
- Fix for Health Connect
- Background sync limitations fix
- Only write Sleep permission is required
- Potential fix for Bad notification posted error
- Lullaby Media notification compatible with Android 13 + pause/resume button
- No need for external storage access permission on Android 13
- Implementing Post notification permission and audio media file access permissions on Android 13
20230613
- Fix for regression in Noise playback on Android 13 related to permissions
- Fix in Bedtime card to only show time to alarm if bedtime is already past due
- Fix in Weather on Morning screen to properly ask for location
20230619
- Fix for a crash in direct boot
- Twitter sharing is back but without media
- Allow up to “repeat every 30 days” for even more use-cases
20230621
- Fix for alarm dismiss from notification on Android 12+
- Twitter V2 support - without media
- Fixes in Health Connect API
- Fix for progress indicator on Tutorial screens
- Fix for Bedtime card shown in case of short duration goals
- On-boarding for the full-screen alarm option for better alarm usability
20230623
- Hiding WiFi control settings on Android Q+ as this is no more possible, thanks Google!
20230627
- Fixed in ringtone picker - playlist vs. single mode
- Auto-refreshing device default alarm ringtone every 8h
20230630
- Fix for inactive notification dismiss button on Android 11-
20230704
- Analog time picker for one-time alarm time changes
20230719
- Fix for using per-alarm smart wake up for “nnot before ideal” smart wake up feature
20230803
- Support for per-app language settings on Android 13+
- Migrating to the latest build tools
- Fix for sleep tracking button when long-pressing quick setting tile in tabbed home screen
