Regression Model
From Will Bowditch on 2015/02/11 11:31:05 +0000
The regression model on the plots is the same colour as the actual data points. I think this is a bit misleading and I’m sure it could be changed straigforwardly.
Cheers.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7081139-regression-model
From Petr Nálevka on 2016/03/09 08:32:19 +0000
Many thanks for your suggestion, the reason is time.. the current plot library we use does not support that, so this would require inventing a view for this from scratch..
From Anonymous on 2016/03/05 16:32:13 +0000
Why not keep the data points the same, but use a smooth curve for the predictions? The plot would look a lot less busy and be easier to understand.
