Redmi smart band pro
Hi,
Is it possible to connect redmi smart band pro to sleep as android app?
Yeay… just baught one for spo2. No luck.
World be nice
Hi, the proprietary OS on Redmi Bands does not provide the required integration options. The device needs to have an API that grants access to adhoc sensor data.
From XiaoMi, only Wear OS based wearables have direct integration.
Mi Bands are the only exception here, because we can collect data from the companion app instead of directly from the sensor. Sadly, there is no such option for Redmi bands.
