[Question] Delete rating
Is it possible to delete a rating I made by accident? I know that I can change the rating, but I can’t seem to figure out how to completely remove the rating. Is it even an option?
@Squidward yes.. if you slide the rating bar completely to the left it is if the records has not been rated..
Thank you!
