Hello, I am trying to link my Miband4 with Sleep As Andrioid thru Gadgetbridge without success. The app does not see the band. Can you please help?
Phone Samsung Galaxy A51
The latest version of SAA
Hello, many thanks for your feedback. I do not think Gadget Bridge would have integration with Sleep as Android implemented, Sleep as Android is currently supported by Tools & Mi Band and Notify & Fitness both support Mi band 4 with Sleep as Android..
@petr-urbandroid I hope it’s ok that I revive this topic.
I have a Mi Band 5 and use Gadgetbridge because of its privacy features. No cloud. FOSS.
The other integrations you mention are all realized by closed source applications that need location permissions to function.
I’m aware that a Pebble integration via Gadgetbridge already exists.
It would be awesome if you could work with the Gadgetbridge developers and maybe create a generic gadgetbridge-integration.
Bumping this ancient topic. I was using “Tools & Mi Band” app for a while but it also required Zepp Life (which is awful) and usually lost connection so in the end I removed it altogether.
I’m getting back into organising my life and being able to have simple alarm on my wrist and sleep tracking with SAD would be awesome. I paired the device with Gadgetbridge and it seems to work fine so it would be amazing if It would be possible to make it work with SAD (as mentioned before - Pebble is already supported so it should be possible?)
