Pre-wakeup noises before alarm
From Anonymous on 2018/01/12 07:43:14 +0000
I would like soft noises to start playing before my alarm.
Now, I try to set two alarms–one with soft bird noises that play softly, and another with loud alarm noises 30m later. This doesn’t work well, as the first alarm requires interaction, and can mess up the second.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/32928250-pre-wakeup-noises-before-alarm
