Could you please add pre-alarms? It is a nice feature some other alarm apps have. The pre-alarm should have these settings:
- time before the main alarm
- select the ring tone
- how long it rings
- smart pre-alarm (here you can set that it should trigger the pre-alarm in light sleeping)
- volume and increasing volume settings
- vibration (someone would like to have pre-alarm just like vibrations on their smart watch, for example)
