Power Nap vs 1 hour wake window?
Curious if power Nap is different from 1 hour wake window on longer sleep durations.
Say I set wake up to 8 and power Nap then I get woken between 8 and 9
Now if 8 set wake up for 9 and 1 hr duration inter woken between 8 and 9 still
What am I missing?
Cheers
V3
Hi @V3ER,
Power nap triggers the alarm after alarm time, other smart alarm methods trigger the alarm before alarm time.
So for an alarm for 8:00:
One-hour smart period → The alarm will go off between 7:00 and 8:00
Power nap → The alarm will go off between 8:00 and 8:59
I was asking for this specific instance, thanks. Is the processing handled any differently?
If the alarm is at 8:00 with the power nap smart period, the smart period is between 8:00-8:59 - after the alarm.
If the alarm is at 9:00 with the regular smart period of one hour, the smart period is between 8:00-9:00 - before the alarm.
For this specific pair of different alarms with different smart period methods, the smart period is almost the same.
