Polar Vantage V3
I’m trying to connect my V3, using the documentation here: polar-ble-sdk/documentation/UsingSDKWithWatches.md at master · polarofficial/polar-ble-sdk · GitHub
I’m really not sure I understand. I did follow the process. Then? SDK streaming is active, what does it mean " From any “exercise wait” view (sport profile selection) you can now stream supported data types (acclerometer, PPI, …) over BLE Polar Measurement Data service."?
Should I keep my polar on a sport wait page during the night? Apart from this, it doesn’t seem to be streaming anything at all to the app…
HI @MattiaCattini, Polar documentation is quite vague, and I am not sure as well, what they meant by this sentence.
What are your options after “start training” (the step before)?
no wait, this document is referenced by sleep as android here: Supported wearables - list - Sleep as Android
so I guess who referenced this has an idea of how the whole process should work?
I fame across this info while installing my Polarh10, not sure if it helps but I guess it wouldn’t hurt to post.
The “exercise wait” view (also referred to as the exercise wait state) is the pre-training screen on your Polar watch where you select your sport profile right before actually starting a workout.
How to reach this view on your watch:
  1. Press the Back button on your watch to open the main menu.
  2. Scroll to and select Start training.
  3. Stop here. Do not press the start button again.
What this screen looks like:
  • You will see the list of your available sport profiles (such as Running, Cycling, Strength Training, etc.) that you can scroll through.
  • There will be circular status icons on the screen flashing or turning solid circles (usually representing your Heart Rate/BLE connection and GPS signal status).
