Polar Pacer Pro integration with Polar SDK
Hi,
I just received a Polar Pacer Pro and tried to test the sleep sensor with Polar SDK.
Although it’s not on the list:
It was added on 20240808 according to the release notes.
Is there a way I could help/test the device to make it working?
It seems it could be fully integrated according to:
Thanks a lot
Peter
UPDATE
I just found out I have to enable SDK on the Watch Settings under Paired devices → my device → SDK → enable.
Now, after i test sensors I have to turn OFF and ON Bluetooth and the device does in fact connect with 10s interval.
Unfortunately no accelerometer data can be seen on Sleep As Android movement chart.
Hello @XedanOlin .. we did not yet test this.. I only see the Pacer should be supported on the SDK page and shoudl support accelerometer data..
I see the latest Sleep as Android uses version 5.6 of the SDK and now theer is version 5.8 so one think we could try is to update.. but not sure if this will help..
Can you please shaer a menu > Support > report a bug with us maybe we find some hints in the log?
Dear Petr
I sent the log a couple of hours ago via email. I hope this helps.
