Polar Loop Integration?
Hi !
Are there any plans to see if the new Polar Loop will work with SAA ?
Thanks
Mark
Hi @Mark_Weiss, Polar only allows integration with some models, via BT or via SDK.
The band will probably use the BT (SDK is for smart watches, not bands). But when I checked the docs, there are no recent updates. So it depends on whether they will add the model compatibility. Or if they added it, but not update the docs?
Do you have the band already?
I don’t think i’ll be getting one, it won’t even broadcast HR cia BT outside of the Polar Ecosystem.
Hi, @lenka-urbandroid, I thought I’d add to this post rather than make my own. Looking at polar-ble-sdk/README.md at master · polarofficial/polar-ble-sdk · GitHub, the Polar Loop is basically the same as the Polar 360 which you already support.
Based on this, would you expect SAA to support the Loop?
Thanks.
