Philips Hue integration no longer working in 20210303 (22273)
Expected behaviour:
  • Pressing “Test” in the Settings → Smartlight menu should flash the selected light
  • Pressing “Turn off” in the Settings → Smartlight menu should turn off the selected light
  • Pressing “Start sleep tracking” should fade out the selected light
  • Alarms should begin a sunrise-like effect on the selected light when they go off and turn the light on fully when dismissed
Observed behaviour:
  • None of the above behaviour is occurring
  • Selecting a light in the Philips Hue Connected menu will flash the light as before
Integration was working as expected in 20210215 (22265) and previous.
Hello @cimsihmm big thanks for reporting this we are preparing a fix for the next BETA.. we will release the fix shortly.. all the best and many thanks!
Just releasing the fix
Can confirm it’s working for me since the update - thanks! :slight_smile:
