From Maurice on 2015/02/19 19:08:05 +0000
I would like to see an option to set the maximum brightness on the new hue lux lights from Philips.
when you dismiss an alarm the lights go to maximum brightness which is way to high.
a slider to set the maximum brightness or perhaps an option to select a scene that is created in the hue app would be a great addition.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7115862-philips-hue-brightness-control
From Štěpán Šanda on 2017/05/06 19:17:12 +0000
Also color ambiente slider would be very nice (white - yellow)
From Anonymous on 2016/05/19 08:53:04 +0000
Yes! A max. Brigthness slider is a must for Hue because they are really too bright at max.
From jobox on 2016/03/09 15:01:54 +0000
More control: color and brightness, would be great!
From Christian Odom on 2015/02/21 14:51:17 +0000
More control of the smart light feature would be nice. Color/brightness /duration/light before audible alarm.
