nice to have new home.
Blockquote Current SaA App-Version: 20190206
Mi Fit-App: 3.5.8/ Mi Band Tools: 3.8.2
Device: Samsung Galaxy S6 Edge
Android-Version: 7.0
Record-Type: Smartwatch Bluetooth
Smartwatch: Mi Band 2 (BT-connected) / Firmware-Version: V1.0.1.81
It seems there is a detection problem with the mi band 2. If you sleep once on your button then it dectects it as a pause untill the end. The button is deactivated in the mi band tools settings.
This bug is semi-repoducible.
It happens often enough, but not every time.
