Get a Pulse Oximeter compatible with Sleep as Android and suitable for whole night oxygenation monitoring HERE.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/devices/oximeter.html
I bought the “StressLocator” pulse oximeter device as suggested in https://docs.sleep.urbandroid.org/devices/oximeter.html
The “StressLocator” bluetooth oximeter device works fine with the StressLocator app AND with the Berry Smart Health app, ie the Bluetooth connection gets established and I can see the SpO2 and Pulse data.
It does not connect with the Sleep app though.
I go to Wearables, Automatic, Pulse oximeter - Bluetooth, I select the “Stresslocator” in the menu of detected nearby devices, then I click Test Sensor but it will never connect.
A bit disappointing since the device is suggested by your website. Is it possible to troubleshoot it and fix it, maybe with a new SW release?
/Stefanos
Hi @Stefanos_Avramidis, Test sensor only works for wearables, that support testing sensor.
If you start sleep tracking, do you see a BT icon at the bottom showing the stress-locator BT address?
