From Evan Burt on 2015/02/08 09:47:16 +0000
An option to disable the default behavior of automatically deleting an alarm set as a nap after it goes off would be great. I usually want to be woken up from a nap the same way that I get up in the mornings, but I don’t take naps often enough to remember that it deletes my default alarm, so I’ve gotta go back in and set it up again.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7067666-option-to-not-delete-nap-alarms-automatically
From Ado Ello on 2016/05/23 20:50:12 +0000
I know it this option. Before this option change to enabled when select nap. But, now the function works well. I don't have this problem in this moment
From Ado Ello on 2016/05/23 01:04:37 +0000
This is easy to make and essential to us. I think is very easy know. For example, one alarm for snap with one characteristics different that others alarm.
