From Viana on 2014/12/31 01:54:53 +0000
I use earphone while sleeping to listen to lullabies before sleep. But when the alarm rings in the morning, it was gradually loud. When I woke up, I got hearing loss for few minutes. I just realized that the alarm actually rings for 30 minutes before I finally wake up. I never use the alarm since then. Hearing loud alarm sound in earphone is dangerous for long term. I hope you can give user option to disable it for user safety. Please consider this, I don’t know why no user has report this problem.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6905027-option-to-disable-alarm-sound-on-earphone
