Could we please get an option for always using the internal speakers? My headphones connected overnight for some reason so I didn’t hear the alarm.
Hi @Aladin_Run, bu default, the app uses the alarm sound stream for alarms (check Settings > Alarms > Alarm output). This sound stream is typically routed only via the phone’s speakers, less often to both speaker and connected headphones.
If you have the Alarm output set to default and your system still used the headphones for alarm sound stream, check the settings for the BT device - there is usually some option to control whether the connected headphones should receive the alarm sound stream.
