Notify & Sleep as Android
I am trying to make Notify work with my MiBand and Sleep as Android, but I can’t find the option described in your help section in the settings of Notify which integrate it with SaA. Am I being a bit thick? This is what I see when I open in Notify the settings for the Sleep section - no icon of Sleep As Android there.
Hello, is this the whole screen you see in that section? The Sleep as Android integration should be at the very top of the same screen (screenshot from the version 14.2.8, which should be the latest):
Hello, I solved it after I realized that in the general Notify settings MiFit was described as “not installed”, even though I could swear I did click “installed” during the set-up. After I corrected it, the Sleep integration icon appeared in Notify settings.
