sorry for the issues. At the moment the preview feature for lucid cues does not support wearables…
If the vibration works in Tools & Mi Band, but does not work in Notify & Fitness this basically means that Notify & Fitness did not implement your vibration call… we use the same Wearabel API to notify integrating apps that they should vibrate the wearable…
We will notify Notify & Fitness author about this…
Many thanks…
There is also no vibration on the signal during REM, sound only, I tested it for several nights. Is there a way to add this feature? Judging by the reviews, the previous Mi band models vibrate even on the preview.
I have a MI Band 2 which works fine with SAA using Notify for MI Band: SAA alerts make the MI Band 2 vibrate.
I just bought a MI Band 6 and the same way (using Notify) unfortunately SAA alerts doesn’t make the MI Band 6 vibrate.
What’s more, I bought Tools & MI Band and SAA still doesn’t make the MI Band 6 vibrate when I choose Wearables / MI Band / Tools & MI Band.
From the MI Fit app, Notify app and the Tools & MI Band app, the vibration works fine on the MI Band 6.
Still, MI Band 6 doesn’t vibrate from SAA…
Any guess, what should I try?
