I’ve used Sleep as Android for several years now and I’m pretty happy with it but I’m interested in getting a nest hub 2 to replace a third party smart speaker and I was wondering how Sleep as Android works if you’re using one. Do they overwrite each other? Do they compliment each other? Does SaA work with the NH2 sleep tracking? Anyone tried this yet? Thanks in advance.
I use both, but can’t really see if they work together or against each other. In Fit i see for some days Sleep and other days Nest Hub
