Naps/power naps/short term sleep
When creating a new feature request, don’t forget to vote after submitting it!
It needs to be easier to add naps. For example, ill take one nap a day for 30 minutes, on other day(s) ill take 3 power naps at 10 min each. I cant find a way to add that type of short term sleep. And adding it needs to be simple and quick.
Hi @Tony_D, to add a sleep entry (of any length), you need to tap (+Add sleep) shortcut, and then tell the app the start and end of the sleep.
What solution would you prefer? Do you have any suggestion on how the process should look like?
Or you can use the Nap shortcuts - it automatically creates alarm of a given duration and starts tracking at once. So you won’t have to add the sleep manually.
