Nap Widgets
From Christopher Kalivas on 2015/04/23 08:00:55 +0000
It would be really useful if you added a widget that would let you quickly select a type of nap and start it, without actually having to go into the app and select it from the door.
On a related note, a dedicated “ideal alarm” widget would also be helpful for days where you don’t have anything scheduled and don’t know when you’ll be going to sleep the night before.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7672269-nap-widgets
