From JP on 2015/08/07 15:00:45 +0000
I can be an alarmingly sound sleeper who, when sleepy, will go to any length to go back to sleep. Because of this, the “are you awake” tests don’t really work for me. I used to use the excellent QR code test until sleepy-me learned how to force quit Android applications.
What would be excellent is if I could install Sleep as Android on my main phone and on one or two of my old Android phones, set my main phone as the master, and when the ideal-sleep alarm time is determined it syncs with the other phones (which are located far from my bed!) so they go off at the same time.
Alternatively, if there’s some way to prevent sleepy-me from force-quitting the application that would be great!
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/9217440-multi-phone-alarm-syncing
