Multi CAPTCHA not working
Whenever I try to use a multi-captcha option to make sure I’m actually awake in the morning the first of the options selected for multi-captcha flashes on the screen then disappears and none of the others ones come up at all. This also happens when I test multi-captcha settings using the preview button in settings.
What’s weird is that I can get a single captcha option to work if it’s selected outside of the multi-captcha settings. If I try to have just one thing selected in the multi-captcha settings, then it just fails to work.
I submitted bug reports/logs today (I may have sent them in before but I don’t remember for sure so I submitted them today just in case) from both an alarm and just trying the preview option for multi-captcha.
Wondering if anyone else has come across this issue.
Steps to reproduce:
I can reproduce this by either previewing the captcha settings with multi-captcha selected or by having multi-captcha selected and using it as the captcha option for an alarm.
According to Google Play I have version 20191212 installed. It just updated today and I tried both an alarm and the preview captcha options and it still failed to work.
Hi Evan,
I know this bug was posted in 2019 but for others who may also stumble across this issue, please try this simple fix below:
I was also struggling with this issue. I found that the root of the problem is the QR/Bar code scanner. If you have the ‘Only at home’ option selected in the QR/Bar code scanner settings, it will lead to this bug. So what I did to remove the bug is to deselect the ‘Only at home’ option when in the settings of the QR/Bar code scanner or to just deselect this QR/Bar code scanner captcha completely.
Hope this helps.
Kind regards,
David
I tried this fix but it still doesn’t work. I tried disabling the “only at home” setting, deleting my saved QR code, and force quitting the app but still the multi captcha only does the first option and ignores all others.
I think this bug is still unresolved.
Hello Ibrahim, if you wait more than 30 minutes to test the Multi CAPTCHA again, will it ask for all tasks?
The Multi CAPTCHA has a security measure to prevent lopping alarms on some phones - and if you already solved the other tasks, only the first tasks is required.
