On every event, Sleep as Android will publish a message to SleepAsAndroid topic in the following format:
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org/services/mqtt.html
what are the allowed protocl prefixes? I am having trouble setting up my connection with EMQX. I was trying mqtt:// and mqtts:// but then “OK” is grayed out. currently I have ssl:// configured (Port:8883) and the Test says OK, but in MQTT Explorer and in my HomeAssistant Tool I see no mention of SleepAsAndroid.
I am totally new to MQTT so I really need help ![]()
My bad, everything is working now.
No matter how i configure my sleep as android setting i never see any mqtt requests reach my server, I’ve tried using it through SSL, TCP, using the subdomain i have it assigned to, direct IP.
No requests ever reach my server despite everything else being able to.
Hi @Racci, if you use the Left ≡ menu → (?) Support → Report a bug, we can check, if Sleep broadcasted your intents.
