From Ryan on 2015/03/24 20:31:41 +0000
It would be perfect if you could either add the ability to change the preset alarm times to times of your choosing, like changing the 15,30,and 60 minute naps to 20,45,90 respectively. That would allow more freedom to choose the alarm presets because some people need more/less than those presets. Thank you!
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7314086-more-preset-alarm-times
