More options for light color for sunrise alarm
I would like the to have an option to either keep the color balance the bulb already uses, or to be able to set it.
I would prefer if the bulb always stayed with a warm white light. The way it’s not is that when Sleep as Android starts its countdown timer, it changes the color temperature to be colder, and it also uses this colder white when the alarm goes off.
_support conversaion_
