From Anonymous on 2014/12/01 23:21:11 +0000
A new icon to match the new layout. And the modern Lollipop/flat design. ![]()
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6790510-minimalistic-icon
From Petr Nálevka on 2015/12/22 21:22:28 +0000
The material design guidelines are quite wide open, can you point me to a section which would show the icon does not comply with the guidelines? Many thanks..
From Udo on 2015/12/22 00:07:49 +0000
#MaterialDesign
