Manually set Lullaby timeout BEFORE falling asleep
From Glibo on 2017/02/17 16:45:58 +0000
I wish to set the lullaby timeout as i want, as a second option next to the current lullaby setting.
For example 3 minutes full lullaby + 1 minute fade away.
Or 1 minute full lullaby + 5 minutes fade away.
In this case the lullaby would stop BEFORE i fall asleep.
The reason for that i that i use lullabys to calm down, however they make it harder for me to fall asleep.
So perhaps in the sleep screen you would have two icons:
  1. Lullaby with fade out after deep sleep is detected as it is now
    and
  2. Lullaby icon which opens a small menu in which you can enter the amount of minutes after it should fade out (and maybe plus an amout of minutes for how long the fade out effect will be)
Hope it makes sense, cheers !
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/18366529-manually-set-lullaby-timeout-before-falling-asleep
