Lucid dreaming alarm cues will play once the app detects you are dreaming (in REM phase).
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//sleep/lucid_dreaming.html
Hi!
This is a cool feature. But I want a vibration on the connected bracelet (mi band 3) to stir me up. Is it possible?
I assume youâve configured the Mi Band 3 in both the SaA app and in the companion app (I use the Mi Band Tools / Tool & Mi Band app).
If so, these settings in SaA work for me (Mi Band 2):
Settings â Sleep â Lucid dreaming â
This should give:
N.B. The âPreviewâ vibrates the Mi Band 2 and the phone, but the actual lucid dreaming cue will only
vibrate the Mi Band 2.
I hope this helps.
Hi, this is a great feature.
Is there a way to get this to work in normal (non-tracking) alarm mode? Like, play âyouâre dreamingâ every 90 mins or a custom interval .
I use the default alarm feature and place my phone far away from my bed (as I tend to switch off/remove my phoneâs battery)
Can you please update the documentation on these settings? For example, what does the sensitivity setting do? I am getting sometimes this cue when I am awake. Should I set the sensitivity higher or lower? Since it should only cue me when REM is detected, are there other settings elsewhere in the app to improve sleep phase detection? Thanks. I love the app!
Mine too, the alarm sounds when I am awake!
Hi all,
please have a look here How we measure your dreams - Sleep as Android.. the article describes how we are doing the REM detection and related lucid lucid dreaming and what are the inaccuracies..
Of course there may be false positives as we are assuming your REM phase from indirect hints rather than actually detecting REM - as for this we would need an EEG.. To minimize thsi kind of issues you can set the Later setting in Settings > Lucid dreaming and make sure e.g. that the cue does not start in the first 2 hours of your sleep trackingâŠ
Jâentends Ă©galement le signal du rĂȘve lucide en Ă©tant Ă©veillĂ©e. Ă chaque fois, câest quand je me rĂ©veille en pleine nuit plus de 2 heures aprĂšs mon endormissement
MI band 6
My settings:
Iâm press preview button but no vibration as result. It is normal?
How does the sensitivity option work exactly?
How can I apply similar settings as described for the mi band reply for a Garmin Vivoactive watch? I have been struggling to use the watch to track my sleep with the app despite itâs ability to do so on its own. I tried downloading the app associated w app to the watch, but was unable to link it to my phone app? Been trying to get this done for 2 years so any help would be greatly appreciated.
Also, I too, have been getting this mostly when I am awake. I adjusted the sensitivity to be lower, which I presume will make it happen less while awake?
Iâm guessing itâs more due to me then the app that this is being triggered, as I have narcolepsy which is associated with fragmented night time sleep. Do you have any other settings which could be useful in this scenario? Thanks in advance!
Hi all ! I have the same problem with my wearable. Iâm using Garmin Fenix 7 which is in the supported device list. Its seem to connect fine, works fine as alarm, but ! Lucid dreaming feature doesnt work properly.
I did the exactly same process and set my settings same as @Deepmind
Even when i try to preview how the dreaming cue will work, the wearable doesnât vibrate at all. Recently I updated the app to the newest version but it didnât fix the problem. Please help !
P.S. Iâve looked through dontkillmyapp so my SaA works fine through the whole night
Enables vibrations upon lucid dreaming cues. If a wearable is connected, the cues will vibrate only on the wearable.
@petr-urbandroid, does SAA send com.urbandroid.sleep.watch.START_ALARM or com.urbandroid.sleep.watch.HINT intent to wearable addon when user enables vibration upon lucid dreaming cues ?
Hello @Den .. START_ALARM is really only for the morning alarm, where HINT is for any vibration cues during the night like anti-snoring, lucid dreaming, low breath rate alarm etc⊠does the doc need updating on this? Many thanks!
