Hi there,
I’m an enthusiastic user of the Sleep as Android app. It’s fantastic! My sleep quality has improved, and thanks to the smart alarm, I’m usually able to get up more easily in the mornings. Great work, and thank you so much for this amazing app!
I have a couple suggestions and feature requests that I hope you might consider:
I’m experimenting with lucid dreaming. Unfortunately, this feature can only be enabled or disabled in the general settings. It would be fantastic if it could be turned on or off for individual alarms, just like you can override the default smart alarm settings for specific alarms.
Regarding the lucid dreaming feature, it would also be helpful to have an option to limit its activation per night. For example, a maximum of 1x, 2x, 3x, etc., per night. At the moment, it seems to activate a bit too often for me.
It would be amazing if you could look into these suggestions and consider implementing them.
Thank you very much, and happy holidays!
Best regards, FK
