From Ivan on 2015/08/12 20:41:01 +0000
A feature that would trigger the alarm based on location when you’re approaching your destination while traveling by train or a bus.
Great for longer distances when you need to get some sleep but your destination is not the final destination of the transit.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/9296886-location-based-alarm
I often go on one-day business trips, 2-3 hours one way and just the time of the trip I have a good sleep. It would be nice if the alarm went off at the entrance to the destination.
When you create an alarm clock, the alarm clock option will appear on the map. A simple map from google map will appear there. You choose a place, hold your finger and the alarm zone grows, you remove your finger as confirmation of the selected area. When you enter the zone, the alarm goes off.
support conversation with Сергей
