Lifesense Band 2 integration
From Avaloen on 2017/10/28 10:55:20 +0000
The lifesense band is similar to the Mi band in functionality and also provides it’s own sleeptracking. Therefore there shouldn’t be any battery problems. It would be great to use it with the Sleep as android functions.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/32053084-lifesense-band-2-integration
From EViLGUARD on 2017/12/03 01:04:16 +0000
I agree, I've bought lifesense m2 since it have Heart rate monitoring and such which would be great to use withing Sleep As Android.
