It is quite annoying to select a time for adding awake. This feature deserves some enhancements.
- One has to click to a tiny place to edit the time (to the spot behind the tiny number). There could be a better method for this input. It is very annoying mainly because of the next issue.
- The keyboard for time input doesn’t have colon so I cannot just quickly delete the whole time and quickly set the time. I have to manually click behind the minutes, edit it and then behind hours and edit it.
- The calculation of the selected time doesn’t work at all when the times are manually added. It works only when I pull the time lines in the graph. So it shows nonsenses and it is confusing.
