Intent-detecting captcha
I use the SAA captchas more similar to regular captchas: To detect that a human is doing them. Only instead of keeping away bots, it keeps away objects or body parts touching the screen and accidentally hitting the “Dismiss” button. I don’t actually want it to be difficult for me. Previously I used the “Sleeping sheep” at difficulty 3, because it increases for every wrong tap, so solving it accidentally by rolling over the phone is almost impossible. But now the graphics there have changed to make it more difficult for a human, without affecting the probability of solving it accidentally at all. No other captcha is impossible to solve accidentally and at the same time trivial for a sleepy human who set an alarm wrong. Could you please add one? It could just be as simple as the sheep, except with 0 wrong sheep. Or maybe some very specific shape to draw on the screen, like an “R”, then I wouldn’t even necessarily have to open my eyes. Combinations of volume and power keys could also work in theory, but would probably conflict with other things.
The pre-typed text for feature suggestions tells me to vote for it after submitting, but I think that’s a leftover from the previous forum, I don’t see vote buttons here.
Hi @Fabian42, the legacy Sheep task is available in the CAPTCHA addon.
Scanning a QR code is easy, fast, and cannot be done by a bot.
If you have troubles with hitting dismiss by mistake, you can configure "long-press to dismiss in Alarms section of Settings.
