Is it possible to integrate with Mibro watches, in particular Mibro GS Pro? They work only with Mibro own program Mibro Fit: mibrofit smartwatch app.
Hi @aksenovaa, does the app or the device have a public-facing API (with real-time access to sensors)?
We use real-time analysis of the data, so we need access to the raw sensor data. I couldn’t find the API mentioned on their website.
I contacted mibrofit:
Is it possible to integrate your watch with the Sleep as Android program - an advanced alarm clock with sleep phase tracking? Link to the program forum: https://forum.urbandroid.org/. For integration you need API for data exchange with the watch (Integration requests - Sleep as Android).
But unfortunately I got a response from them:
Thank you for contacting us and your kind support for Mibro. We are truly sorry that this function is not supported.
I was afraid this would be the case… in most cases, the platforms are closed, so the users keep using the native app (so a business decision). We can only hope that they will reconsider in the future, we still believe that opening the devices to integrations benefits both the users and vendors.
