Could you please add integration for Huawei watch 3 watches (harmonyOS (like Android 10 OS without GMS)?
There are all sensors and please, add alarm synchronisation for there watches.
Thank you for your return.
Hi, do you have news for this?
please check the state of wearable integrations here:
https://docs.sleep.urbandroid.org/devices/wearables.html
We do not have Huawei wearables integration. For long time there were no APIs..
Now there is one API which developers may start using:
But this does not include accelerometer sensor so we cannot do actigraphy
There is another API which may be potentially useful
but at the moment this is not public and no details about what will be possible are known..
So this is bsically it as of Feb 2022 IMHO
So when will this be a thing for HarmonyOS on my Huawei gt4? Please explain the steps to make it work
Hi @Stass, as soon as Huawei shares an open API for the integrations, we can design a companion app for the HarmonyOS devices. But it depends on the public-facing API. We need access to the sensor data in real time via an official API.
It looks like there now is a Health Kit in HMS Code containing Sleep Data here: Document
Does this serve this purpose?
Or as another idea: Would it be possible to integrate Huawei Watches via Gadgetbridge?
Hi @Leon_Schmidt,
the data type they provide is “sleep” (so already analyzed and processed data), or “activity records” (speed, step cadence, altitude, jump, running form, power, resistance, stroke rate, and rope jumping speed).
We need a direct access to the movement data from the sensor.
