Integration Huawei watch 3 pro
Hello, even though you say that Huawei has no support, but on huswei watch 3 pro, you managed to install your app, even though I bought your program, I’m ready to buy more if you slightly change your app to fit the watch
The application uses the clock accelerometer, I will be very grateful to you and am ready to test versions, perhaps you can even simplify the application itself, since you do not need to connect to the clock Api
https://drive.google.com/file/d/17f8kmbynmcs3RPXE5kq-lebgKkcfuopP/view?usp=sharing
https://drive.google.com/file/d/17j_uXNE3Vv4QxnLoK2ff1shiaxaFWIyu/view?usp=sharing
