Integration for the Playbulb Candle
From Spencer Martin Navarra Chew (smnc) on 2016/12/30 07:00:25 +0000
I discovered the Playbulb Candle at BestBuy and it’s a great little device with a ton of potental and an attractive pricetag (~CDN$15).
It’s a BLE battery powered smartbulb and I’ve been looking at the various unoffical uses for it.
This one:
in particular seemed like a great idea and seems like it would be a fairly simple plugin too.
GitHub - Phhere/Playbulb: tools for communication with Playbulb led lights (Candle, Rainbow,..)
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17575786-integration-for-the-playbulb-candle
